Old 03-19-2017, 08:38 AM   #1
GracefulCamper
rocknroos's Avatar
Water pump inlet screen bowl
Yesterday I was getting something out of my hybrid and I noticed a piece of round plastic with a small screen in bowl laying on the floor right next to my water pump. I soon found that I must have had some water left in the bowl when I winterized. Well guess what it froze and broke the bowl at the threads. Does anyone have any information of where I can get a new bowl for the water pump inlet screen?
2017 Roo 19
2010 Lincoln MKT
rocknroos is offline   Reply With Quote
Old 03-19-2017, 08:43 AM   #2
Herk7769's Avatar
https://www.amazon.com/SHURFLO-255-2...p+inlet+screen
This will do it.
HAM CALLSIGN - KC3FFW
Old 03-19-2017, 08:55 AM   #3
If your "Pre screen filter bowl" was frozen you should check your Pump and Filter housing also! Did you just use Air for "Winterizing"? Youroo!!
Old 03-19-2017, 09:06 AM   #4
I had this happen to me this weekend as well. Word of advice just buy the whole thing and replace it all. I bought two different ones and each bowl still leaked.
Crshamp is offline   Reply With Quote
Old 03-19-2017, 09:10 AM   #5
SeaDog's Avatar
Pat yourself on the back for finding it now and not on your first outing.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-19-2017, 09:11 AM   #6
GracefulCamper
rocknroos's Avatar
I used air to winterize. I to have some concern about the water pump. I am hoping that this is a low point and any water in the pump housing drained back into this inlet filter. Filter housing was removed after I winterized the system so no issues there.
2017 Roo 19
2010 Lincoln MKT
Old 03-19-2017, 09:28 AM   #7
That is why I ask,Air Winterizing does Nothing for your Pump,the chambers will retain water! Lots of Members do the Air Method but if you check their Location they Live in Warmer Areas,But they also get caught in a "Freezeing" once in a while! Youroo!!
Old 03-19-2017, 09:47 AM   #8
SeaDog's Avatar
On my old Class A I always air winterized but that unit had a drain right under the pump. I now use RV antifreeze because of the ease with this new TT. I actually feel for me using the RV antifreeze is a more sure way to winterize.
Retired Navy
Old 03-19-2017, 09:48 AM   #9
DAISY BOYKIN's Avatar
FROZEN
If it is the water pump bowl and screen, Camping world has the complete screw on assembly for the bowl and screen.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-19-2017, 09:55 AM   #10
As inconvenient as it is for me to reach my water pump, I remove and empty the bowl, reinstall, blow the lines and empty again.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 03-19-2017, 10:08 AM   #11
Ret E-9 Anchor-clanker
donanddona's Avatar
Using air, I have done this also. Using antifreeze the suction is on inlet side of the strainer, so it is protected. The replacement bowl is an easy task, it just screws off/on. I also use air when winterizing but it has never hurt the pump. Additionally while winter camping one year it got so cold (used to much ceramic heating, not enough furnace) my FW pump quit one morning. Opening doors and turning up the heat allowed the pump to work. Still use it today (4 yrs later). Guess I'm the lucky one...
donanddona is offline   Reply With Quote
Old 03-19-2017, 01:16 PM   #12
Pump bowl replacement
I get my replacement bowl at a Farm/Tractor store.
saltyman is offline   Reply With Quote
Old 03-19-2017, 01:39 PM   #13
Same problem, different fix.
I had the sediment bowl with the screen in it freeze also on a new motorhome. I used anti freeze, not air, but my bowl was also on suction side of pump but did not receive anti freeze due to shutoff to keep antifreeze from FW tank. My water pump also had push drains for intake and outflows. I also did not have suction line for antifreeze. So my cure was to buy antifreeze valve with suction line and remove and toss filter and replace it with the new winterizing valve and all were same threads so I now had a winterizing valve. I installed inline filter in my fresh water hose to motorhome or tank fill. Just my cure since I didn't have a winterizing valve. YMMV
Old codger is offline   Reply With Quote
Old 03-20-2017, 08:01 AM   #14
After removing the filter from the inline filter canister, I use air to blow out all the lines (including opening all the ball valves in the bypass path). Then I draw just enough antifreeze in through the winterizing port to see it in the filter canister. This insures that the pump (an its screen bowl) is protected. I also then loosen the inline filter canister to "open" the threads to prevent breakage if water were to be trapped there. Works for me to -20 F.
DRiveWell is offline   Reply With Quote
pump, water, water pump
