Old 11-28-2016, 08:55 PM   #1
Water pump inoperative
Cedar creek 38 fb2 - full tank - pump runs but seems weak - no water at any faucet. Happened suddenly.
Mike.............
Orange Beach Al
Mike & Sharon 2011 Cedar Creek 30RL
Dodge 3500 Mega Cab
MBeech is offline   Reply With Quote
Old 11-28-2016, 09:05 PM   #2
Mr. Dan's Avatar
What's the charge level of your battery?
Are your LED lights bright or dim?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 11-28-2016, 09:10 PM   #3
SailorSam20500's Avatar
Did you check the small filter that is just in front of the water pump? My rig has a small strainer similar to the aerator on a sink faucet. It could have plugged up.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 11-28-2016, 09:31 PM   #4
I burned out my water pump by stupidly leaving the pump on when breaking camp. As I had a full water tank, I opened the drain for the trip home. Pump ran dry, and no longer worked. Water pump switch in the cabinet under the sink is easy to forget - $65 for my forgetfulness. I disconnected the inlet plumbing and replaced with a piece of hose into a bucket to make sure I had no vacuum leaks, and confirm pump was shot.
When I installed the replacement, I couldn't get it to work either. Turned out I had cross-threaded the inlet filter connection (and had a suction vacuum leak). Got it correctly threaded and installed - and all was good.
Fred W
2014 Rockwood A122 A-frame
Old 11-28-2016, 09:31 PM   #5
Battery is up -bright leds
Will check the filter
Mike.............
Orange Beach Al
Dodge 3500 Mega Cab
Old 11-28-2016, 09:38 PM   #6
VinceU's Avatar
Sounds like air leak, check suction strainer, screwed and clamped fittings leading to fw tank.
Old 11-28-2016, 11:38 PM   #7
Water tank filling when connected to city water
I have a 2014 heritage Glenn 312qbud bunk house. My fresh water tank is filling up slowly over a day or so when connected to city water at a campground. Eventually the overflow begins to release water until I shut off the city water and use my pump until the tank is dry. I have read a check valve in the pump itself could be causin this? Also I cannot find the water pump, can anyone enlighten me? Do I have to remove the sealed bottom to find it? Any advice would be greatly appreciated...
fourarbys is offline   Reply With Quote
Old 11-28-2016, 11:47 PM   #8
I don't know your trailer. But, if the pump is not accessible from outside, it is probably behind a panel in one of your cabinets. The back panel in many cabinets are intended to be removable, may need to undo a couple of screws. I've also heard of them being under a bed. It will not be inside the sealed bottom.
Hopefully, someone with your model trailer will chime in with a location. Do you recall where you heard the pump when it was running?
Al
Old 11-29-2016, 01:12 AM   #9
yea it sounds like it's behind the refrigerator or possibly behind the pantry? I have an access door under the bathtub and I see the water lines, but no pump. I will check in back of cabinets.
pump, water, water pump
