Water pump issue?
When I started my Spring opening procedure, the water pump wouldn't work although water pump switch was lit. Turned out the red power wire spade connector had separated from the pump. Couldn't make a real firm connection so I taped the connector to the pump and its worked OK over 4 trips - elec. and dry camping.
On our last trip (dry camping), it again separated so I taped it again and worked for balance of the trip.
Here's my question. DW was running water and I happened to check the battery monitor. The red lights flickered back and forth from 3 to 1 light. With pump shut off went back to the normal 3 lights (fully charged).
I'm now home on shore power (4 lights) and decided to run the pump and the monitor flickered back and forth from 4 to 3 lights.
Does this flickering sound normal? I guess I've never before checked the battery monitor while concurrently running the pump. Thanks and sorry for being long winded.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
