Hello, I'm new to the forum. I have a 2014 Stealth Toy hauler. I turn my water pump and hot water on for a weekend trip. When went to use the water didn't nothing come out. So thinking my wife might have turned the pump off I go to check and both lights on the switches were off but the switches were still in the on position. So I flip the hot water switch off then back on and the light on the switch came back on. But when I flip the water pump switch off then back on the light on the hot water switch went off and the water pump switch light never came on. Does that mean the water pump is bad or is it a fuse somewhere that's blown.
Have you checked to see if the water heater is in bypass?
Do you own a multimeter and know how to use it? Five minutes with a meter will answer a lot of questions about whether the switches have voltage and are operating properly.
