Old 09-20-2020, 09:47 AM   #1
Water pump issues
Our water pump starts but just a little water comes out then it hisses and stops. One year old 21 mini lite camper. Weve always been hooked up to water and just found this issue.
rgklever is offline   Reply With Quote
Old 09-20-2020, 10:30 AM   #2
Just Tryin' to Help
cboss's Avatar
Does your fresh water tank have water in it and is the valve from the tank in the correct position? The valve may be in the "winterize" position.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 860
cboss is offline   Reply With Quote
Old 09-20-2020, 10:52 AM   #3
nomad297's Avatar
When you say it stops, are you saying the pump stops or are you saying the pump continues to run, but the hissing stops? If the latter, I would agree with cboss that your diverter valve is in the winterization/antifreeze suction position. Flip the switch on the valve and see what happens.
Bruce
nomad297 is online now   Reply With Quote
Old 09-20-2020, 12:14 PM   #4
Bruce
The water stops flowing. Where is this valve located?
Old 09-20-2020, 12:20 PM   #5
Just Tryin' to Help
cboss's Avatar
Usually right near the input to pump. It will be on the water line from the tank.
Craig & Cath
Old 09-20-2020, 12:59 PM   #6
Thanks. I’ll check it out.
Old 09-20-2020, 01:47 PM   #7
bikendan's Avatar
It would help if you posted year and model number, since valve locations vary wildly between brands and models.
Old 09-20-2020, 02:08 PM   #8
Also... do you have a ShowerMiser valve on your shower? It may be in the wrong position orcracked.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 09-20-2020, 07:05 PM   #9
Thanks everyone! The valve was on winterize. Appreciate the help!
pump, water, water pump
