Old 10-10-2018, 10:11 PM   #1
Water pump location on an Ultralite
Not sure where the water pump and valves are on my trailer so that I can winterize it. Maybe I am overlooking it in the manual, but can anyone point me in the right direction?
Wingfield is offline   Reply With Quote
Old 10-10-2018, 10:31 PM   #2
I will tell you if you tell us what unit RV you might have! Youroo! !
Old 10-10-2018, 10:32 PM   #3
Mr. Dan's Avatar
An Ultralite what? What manufacturing line?
Old 10-10-2018, 11:19 PM   #4
Certified Curmudgeon
Water pumps are fairly noisey. Turn it on (they can run w/o water) and follow the noise. Your winterization suction hose and valve will be near the pump (if you have one). Your bypass valves, normally three of them, will be near the back of your water heater. It really does not matter if you have a towable or a motorhome. The water system is pretty much the same unless you have a tankless WH.
Your manual should have good info on how to winterize and sanitize but very little specific info.
Edit: Sorry I was remiss. Welcome to the FRF.
Mike Dropped
cat, lite, location, pump, ultralite, water, water pump
