A very loud fresh water pump when first turning it on may be due to a pressure leak somewhere. When the water pump is turned on and the pressure is built up and all faucets are closed the line pressure should stay up in the water lines. If this water line pressure 'bleeds' off, you have some type of leak in the pump/lines/faucets. Not a big problem if you turn your water pump off when not in use. If you use/are on, city water and leave the city water on all of the time, if there is a line leak some where, this could become a problem.
Brother Les
