Old 02-21-2020, 08:41 PM   #1
Water pump not stop
We have the same problem few months ago so I changed the water pump now it's happening again.
So what's happening after I changed the water pump everything was ok.
Today I was need to use the water pump because the city close the water.
After water come back I close the switch for the pump and now the water from the city keep filling the fresh tank non stop.
What can be wrong here?
Any help will be appreciated
NickClick image for larger version
ID:	223763Click image for larger version
ID:	223765Click image for larger version
Nivbin is offline   Reply With Quote
Old 02-21-2020, 09:00 PM   #2
Flybob's Avatar
Turn off city water
Turn off water pump
Open faucet and run water till it stops
Turn on kitchen faucet
Let it run about 1 min
shut off kitchen faucet
wait for pump to stop
turn off pump
turn on city water.
Should be OK, as it should have reset the back flow valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-21-2020, 09:29 PM   #3
It's don't do anything. Soon when I'm open the city water it's I start filling again
Old 02-21-2020, 10:05 PM   #4
Ok so another thing.
Today want to city water was out I didn't close the value outside so when the city water come back the water pump we on.
Don't know if it's related or no
Old 02-21-2020, 10:10 PM   #5
Did you follow FlyBob's instructions? That usually resets the valve that is stuck open and fills the fresh water tank.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 02-21-2020, 10:38 PM   #6
SOLVED!!!!
Ok so what I did is just open the pump took two parts outside like in the picture and then put all back and now it's look like it's work again.
Thanks For the help.
Old 02-22-2020, 07:39 PM   #7
DouglasReid's Avatar
Originally Posted by Nivbin View Post
SOLVED!!!!
Attachment 223769
IF you had followed Fly Bob's advice and instructions it would have been fixed faster and easier.
By taking it apart You accomplished what he suggested without having to go to all that work and trouble.
Live and learn!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-23-2020, 12:28 AM   #8
Live and learn!
This method didn't work in the first time I have a problem and not in the second!
It's only 8 screws to take out and in, pretty simple things to do [emoji6]
pump, water, water pump
