Sounds like it isn't actually shutting off but rather running until the thermal overload switch cuts out.
As Bama mentioned, maybe the pressure switch isn't working. They are usually built into the head of the pump. You might check the voltage through the pressure switch and if not opening, pull a wire off the pressure switch (when pressure builds) and see if that stops the pump.
