Old 02-19-2017, 10:15 PM   #1
SailorSam20500's Avatar
Water Pump Question
I'm in process of planning the install of an accumulator tank. As I do this, I'm thinking of rearranging the area where the pump is located. I suspect, but because the trailer is miles away, I can't check...
Question is, are the two elbows attached to the pump the swivel type? That is, is the elbow two parts, the 90 degree pipe and a screw cap that allows the elbow to point in any direction and still have a tight connection?
I suspect they are because mine are pointing in different directions. I'm attaching a picture of my pump.
As I do this, I'm going to remove the water filter and set it up to be used external to the trailer. By moving the pump, I get some room for storage.
Name:	Pump fitting.jpg
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 02-20-2017, 06:24 AM   #2
bubbles's Avatar
Yes
pump, water, water pump
