Originally Posted by 5picker
How much water have you run through the water pump?
Sometimes on initial start-up of using the on-board pump, air can get trapped in the lines and create a false pressure point. Sometimes just using some water (at various locations) can resolve the issue if you are certain there are no leaks.
Last spring we took a trip to San Diego and used shore water. Two weeks ago we boondocked. I'm going to say that we ran appx. 10 gals. thru the (aft) kitchen sing and maybe 30 gals. into the (forward}toilet.
The pump ran often enough (1 sec. bursts) that we shut it off unless we needed it. Not only was it annoying, but we were worried about battery consumption
