Old 04-26-2017, 05:20 PM   #1
Usually Confused Member
emm-dee's Avatar
Water pump replacement
I'm going to get a new water pump to use for filling the fresh water tank from an external 50 gallon tank (Vengeance trailers cannot be filled via gravity...have to have pressure). My current installed pump is a Shurflo 4008-101-E65 which if used for the external fill project would be acceptable.
Question is does anyone have experience with replacing the standard Shurflo (3.0 GPM and 55 psi) with a pump putting out 5.0 GPM at 60 psi? Would it be noisier or have too much pressure?
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 04-27-2017, 09:20 AM   #2
RV Parts Manager
in many cases youll be fine replacing the pump with the 5gpm 60 psi, as far as sound goes what unit will you be using?
Henry Conoly
RV Parts Manager
FF602956 is offline   Reply With Quote
Old 04-27-2017, 09:52 AM   #3
emm-dee's Avatar
Looking at two different units:
https://www.amazon.com/gp/aw/d/B01CO...=rv+water+pump
And
https://www.amazon.com/gp/aw/d/B018A...03L&ref=plSrch
Old 04-27-2017, 10:03 AM   #4
RV Parts Manager
personally id go with the SEAFLO as it is a higher quality pump. It will have a similar noise level to that of a shurflo.
Henry Conoly
RV Parts Manager
Old 04-27-2017, 10:08 AM   #5
In the pictures on the websites, both pumps say SEAFLO on the motors!
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-27-2017, 10:14 AM   #6
RV Parts Manager
the fact that no where else in the product description does it say seaflo makes me believe that it is a stock image and not a seaflo pump.
Henry Conoly
RV Parts Manager
Old 04-27-2017, 10:20 AM   #7
emm-dee's Avatar
Yeah, they appear to be the same unit in different colors. The Seaflo has Prime shipping.
Old 04-27-2017, 11:13 AM   #8
Sounds like bait and switch!
Old 04-27-2017, 12:17 PM   #9
emm-dee's Avatar
Hmmmm. Chinese knock off?
Old 04-27-2017, 12:24 PM   #10
candidly, I'd trudge down to your local TSC or farm store and get it there They all carry Shurflow pumps because it's an ag item. Used in spray applications.
Don't get an import knockoff. Get the best the first time.
SidecarFlip is offline   Reply With Quote
Old 04-27-2017, 12:31 PM   #11
Just A Member
EDABEUT's Avatar
I just bought a 60 gal water storage bag and pump myself for when we stay at CG's with no water hookups. I was going to do the same thing and buy a replacement pump that would work in my TT for when one goes bad.
The problem is RV water pumps are pressure pumps. They turn on/off by pressure needs in water system. What you need is a transfer pump so you can manually turn pump on/off as needed. I ended up buying this one.
https://www.amazon.com/PC2-Portable-...transfer+pumps
You could probably mess with the pump and make it work but I elected not to and just bought what I needed. $85.00 on Amazon.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 04-27-2017, 12:56 PM   #12
ben31's Avatar
Are you going to leave the water bag in place or place it on the bed of your truck, or?? If you are leaving it in place, and you have a winterizing hose, why not just extend that hose to the new tank? Switch the input from the onboard tank to the hose. You wouldn't need to buy an additional pump. It should work fine, since the pump will simply pull the water from there, instead of the onboard water tank.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 04-27-2017, 01:11 PM   #13
emm-dee's Avatar
No winterizing hose setup on my rig. I just use air and it has worked fine. I haven't decided on the water bag or a 60 gallon plastic tank I already have, but leaning toward the bag mainly for space saving. I've also discovered a 115 volt ac pump will be a lot faster.
I'm currently building a double stack rubber pad to mount the RV pump on and if it eliminates noise and vibration as hoped then I'll go with the AC powered pump.
Old 04-27-2017, 01:11 PM   #14
AquaMan's Avatar
Actually RV pumps turn OFF by pressure and turn on when powered. They will continue to run until pressure is built. They would work just fine for a transfer pump.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-27-2017, 01:19 PM   #15
emm-dee's Avatar
The standard RV pump will run fine until it senses pressure buildup on the output side. Since the flow from the pump won't see back pressure until I move the supply valve lever from the fresh water fill to city water supply then it will run continuously. Once I move the valve the pump will sense the pressure build up and shut off (50-60 psi).
Old 04-27-2017, 01:53 PM   #16
Just A Member
EDABEUT's Avatar
That's true it will not shutoff by itself. As long as your neighbor don't stop over and start talking to you and you forget to shutoff the valve you will have no problem. At least it just the fresh water tank. Ask Aquaman how he knows about this.
Ed & Brenda
Old 04-29-2017, 08:47 AM   #17
AquaMan's Avatar
I recall something like that happening. The details are a little fuzzy.
pump, replacement, water, water pump
