Cavitation sound? I had to look that up and I still don't know what sound you're hearing. It sounds like you think there is a leak back there and you could be right. If they didn't winterize that shower line, it might have developed a leak. It's an easily overlooked connection.
The water pump continues to run if it's trying to pressurize the lines. I suppose it could continue to run if it's been pressurized.
At this point, you probably could check by running the pump and check fresh water indicator and see if the level continues to go down. If it does, the leak could be anywhere and the water could be filling the underbelly.
2015 Dynamax REV 24TB class C
