Originally Posted by Larry-NC
Also possible that the check valve (one-way valve) in the water pump is not seating properly. The pump builds up pressure in the plumbing and stops. Then the pressure causes water to seep backward into the fresh water tank. As soon as the pressure drops a little, the pump runs again. You never lose any water but it's annoying and runs the battery down.
There are a couple of options. - You could try letting the pump run and build up pressure. Then turn the pump off and bleed off the pressure by opening a faucet. Then close the faucet, turn on the pump, and repeat. This might clear out a small particle that was preventing the check (one-way) valve from fully closing.
- You can take the pump apart and clean the check valve.
- You can simply buy another check valve and mount it externally on the pump output side.
I had the identical check valve issue. Couldn't understand why my fresh tank was filling up while I was on city water! Ended up just replacing the water pump with it's built-in check valve. Also be sure all hose fittings around the pump area are properly clamped tight with pex clamps or similar. If you are getting just a little air in your lines from that issue, you can never clear the line of air and it too causes the pump to cycle much more often.
ArkRVHog
2018 Forester Model 2801 QSF
Katy, TX
OTR 2024-22 / 2023-29 / 2022-52
2021-51 / 2020-29 / 2019-71 / 2018-49
