04-17-2015, 08:10 PM
#21
Originally Posted by fonzie
Looks like the valves are in summer position. The one by the cold water line is a three way valve which looks is set for water to flow to water heater. Red line is hot water line and valve looks like it is open, so water should flow properly. Turn water pump on and open only hot water faucet and wait until water comes out steady for one minutes and that should be it. To make sure water hater is full you can also open water heater relief valve to make sure tank is full.
PS: I did say to look underneath bed.....
That worked! was not letting the hot water run long enough to empty out all of the air. now the pump shuts off and only goes on when I call for a water hot or cold.
Fonzie, you help me out with my weight distributing hitch problem and now with this thank you. I owe you a big beer around a campfire! and also I want to thank the other posters for their help also really do appreciate it.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
04-17-2015, 08:18 PM
#22
Glad it's all working for you.....
Fonzie
04-17-2015, 08:37 PM
#23
Good you found them and everything is working. Remember to open the low point drains and flush them as well. There is antifreeze in them as well, otherwise mixing with some chlorinated water the water will stink really bad.
B and B
04-17-2015, 08:55 PM
#24
Thanks !!!!!!!!! On the way out to my driveway to do that now! Didn't realize that had to be done! This forum is AWSOME!!!
Philadelphia PA
04-18-2015, 05:17 PM
#25
With the HW tank is located at the front maybe the factory did not install the necessary piping to bypass it or they have run the piping to some other part or panel of the trailer. You can still fill the tank most of the way full by manual procedure--Open the HOT Water faucets so as to relieve the back pressure on tank and remove the pressure valve near the top part of tank (It's the little Do Hicky with a leaver attached) and use a water hose to fill most of the tank. Turn on switch for your pump and water should flow from the removed pressure valve hole within a short time period. Stop pump and reinstall the pressure valve with pipe seal on the threads. Close faucets and lines should pressurize with use of pump when started again.
04-20-2015, 02:57 PM
#26
Thanks for the reply, I found the access panel with the help of Fonzie, previous page. All is working as should be!
Philadelphia PA
04-21-2015, 10:29 AM
#27
Also be sure the hot water heater plug is in tightly. If wh plug is not in and bypass is to summer position the pressure to stop the pump will not build up.
RetCityMan
04-24-2015, 08:36 AM
#28
RetCityMan
Where is the WH plug located at, for future reference?
Philadelphia PA
04-24-2015, 08:51 AM
#29
If by pass valve is in correct position make sure WH plug is in the unit and tight.
RetCityMan
04-24-2015, 09:49 AM
#30
RetCityMan
When you say "WH plug", are you referring to the bolt/ annode rod?
Philadelphia PA
04-24-2015, 10:03 AM
#31
I didn't make the post, however, I'm sure your correct. Plug = water heater anode.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
04-24-2015, 10:09 AM
#32
Thank you, that is the only thing I think of as a plug.
Philadelphia PA
04-24-2015, 05:57 PM
#33
That's correct, there's nothing else.
04-24-2015, 06:12 PM
#34
It looks like you have the different valves figured out so try this. I had this problem once. The fresh water tank pipe that feed the pump probably has an air bubble in it. fill the fresh water tank and then put the hose in the fill port and put something around the hose to keep water from flowing back. What you are attempting is to pup pressure on the fresh water tank to force the air bubble out. Any excess water will come out of the vent pipe so look out so you don't get hit with that water. It does not take much to force the bubble out. If this does not work, make sure there is a path for water between the tank and pump. Good luck
04-24-2015, 09:06 PM
#35
Thanks for the tip! Will keep it in mind if this happens again. Have a nice weekend!
Philadelphia PA
04-25-2015, 06:01 AM
#36
Wish i seen this sooner. Where in philly are you?
2017 Freedom Express 271bl
2013 Silverado Z71
04-25-2015, 11:51 AM
#37
Northeast, Rhawn and Roosevelt Boulevard. Are you from Philly?
Philadelphia PA
04-25-2015, 02:20 PM
#38
Never mind, I read you Bio and know you are not from Philly.
Philadelphia PA
