Old 03-08-2022, 10:21 AM   #1
Water purification issue, HydroLife installed
Hello (newbee alert....)
I recntly bout a 2007 Pursuit Class A. It has an installed water purification system, which looks like a modified HydroLife cap customized and "hardwired" into the water system (instead of using the standard hose fixtures for in/out it has elbow joints that go back behind the water station board.
https://tinyurl.com/yc5x745x (photo)
The cap has no brand/model info that we can see... we assumed it was a HyroLife because that's what the attached canister is. The problem is the canister is cracked and leaks, so we tried to get a replacement. The new HydroLife canister with the same model # has different threads and is a little longer, so it won't screw on to the cap.
My question is: does anyone know of other canisters that would work?
I'm hoping to avoid having to rip this all out and bypass (and run an external canister), as we're hitting the road and it would be a lot easier just to screw in a new canister that fits.
Thanks!
https://tinyurl.com/2p96ax3d (photo 2)
Great Brewery Tour is offline   Reply With Quote
cat, led, water
