Old 05-07-2017, 10:53 AM   #1
Water Shutoff?
Hello i had my 3170ds winterize and i not want to get it ready for the season.
i put water in the holding tank and it runs but acts like it is shut off going to the pump not a lot of pressure and lots of air. I cannot hear the pump running is it possible to have a valve shut off or the motor turned off? Any suggestions.
sunseeker3170ds is offline   Reply With Quote
Old 05-07-2017, 11:11 AM   #2
sgtlm17's Avatar
First check the valve that is on water line that connects winterizing hose to pump . It sounds like it may be set to the winterizing hose instead of the FW tank. Very common problem when dewinterizing.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-07-2017, 03:34 PM   #3
Only one valved
It looks like the only valve is to the drain line.
I made sure that was closed and still not working great. It is working i am starting to think the pump is going bad...It does cycle but not alot of pressure. Dont see any other valves.
Old 05-20-2017, 07:20 PM   #4
sgtlm17's Avatar
What year is your 3170? The last few years they all come with a winterizing kits
2011 Jeep JK Toad
water
