Originally Posted by Crayfay
Ran into issues on my 2021 Wildwood 27rk. The fresh water tank bracket broke and tank fell out bottom. Also found the flooring squeak s a lot. Any similar issues? Today while camping I found water pouring from the bottom of camper while my wife showered. Found the p trap was not supported and separated.
Son's travel trailer fresh water tank was sagging badly when full. So we installed two 10 foot lengths of 1 5/8" Unistriut with clamps on each end of the two Unistruts. You will have to cut the Unistrut to fit your application. The "U" clamps slide over the Unistrut with the "U" facing down and the angle plate contacting the frame.
We drilled and bolted the ends of the strut to the TT frame to ensure everything was secure. Home Depot carries what you need.
