Old 09-01-2014, 07:31 PM   #1
Water tank for toilet
How do you empty the fresh water tank for the toilet, I hope we don't have to flush it all?? any idea how many gallons it holds?? Thanks!
WeRock2716g is offline   Reply With Quote
Old 09-01-2014, 07:40 PM   #2
You supplied a LOT of Info? What color is your toilet,is it a 17" tall one, Is the Tank on top of the RV? Youroo!!
Old 09-01-2014, 07:48 PM   #3
It is white in my 2716g popup, I don't know how tall it is!
Old 09-01-2014, 07:48 PM   #4
vinmaker's Avatar
I am new to the whole toilet with black tank issue as well. So I am not the most knowledgeable person.
I thought the city water line pressurized the toilet and provided water. I do not think it runs off a storage tank unless your boon docking and using your pump.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 09-01-2014, 07:52 PM   #5
vinmaker's Avatar
Ah. A pop up. Now we may be talking.
If you have a cassette toilet made by Thetford, then the water tank is right under the toilet seat area and the sunken toilet paper holder. You need to access the fill outside the pop up.
Go outside to the area where the toilet is inside. There will be a locked door. Open that and you will see a yellow cap towards the top of the opening. Grap that and gently swing it out. Open it up and pour in a mixture of water and sewer treatment (blue stuff, Orange stuff, etc). It should hold about 3 gallons. Just use a normal milk jug to transport water from the sink.
Piece of cake.
Vin.
2015 HW296
2013 Chevy Tahoe
Old 09-01-2014, 07:58 PM   #6
Vin, he wants to know how to EMPTY the fresh water part of the toilet, not fill it.
2011 Traverse LT, 3.6L, FWD
Old 09-01-2014, 08:07 PM   #7
vinmaker's Avatar
hahaha. Oh boy. too much wine.
Ok. If you look to the side of the opening (It was left on my unit but could be the right hand side as well). You will see a clear tube used as a level sight to tell you how much water you have in the holding tank. You want to pull it off the side wall. It is just pressed into place. It is connected to a rubber hose that will allow you to tilt it down to drain it out. I drained mine back into a jug to save for next season since it held the treatment (blue stuff). You can also unscrew the small yellow cap below the large yellow one that you open to fill it up.
Vin.
2015 HW296
2013 Chevy Tahoe
Old 09-01-2014, 10:21 PM   #8
Cool, thanks!!
tank, water, water tank
