Originally Posted by Barry Allen
Thank you for your replies.
Yes, ShowerMiser. My mistake.
- connection is not at the pump. However, I do see a line plumbed into the top of the fresh water tank. That has to be it. No other pipe would enter the top of the fresh water tank other than the fill hose which is adjacent to said 1/2 pipe.
- I can't imagine a pinch or kink achieving a total blockage. I put compressed air on the ShowerMiser return line at the shower tap and there is absolutely zero flow into that line.
Barry
Typical fresh tanks have a drain line, (near the bottom) a pump supply line, (near the bottom) a fill tube, (near the top) a vent line, (near the top) and some have an overflow line. (also near the top) Systems with w ShowerMiser have an additional return line plumbed into the tank somewhere. Some go directly to the tank some return to the pump supply line.
Don't discount you have a pinched line or a kinked line.
A photo of a neighboring camper with issues to their new rig.
Here is a factory photo of a fresh water tank. Picture is upside down to how it is installed in the R/V. I added the notations.
Finally a photo of my supply line.
It wouldn't pass air or water either.
