Loosen those three screws (no need to remove completely) at the top of the housing bracket and slide the assembly slightly up and out of the enlarged holes. It will be somewhat tight moving with the plumbing connected but that will allow you to tip the assembly enough to remove the canister.
Be sure to loosen the canister first.
