Originally Posted by LRCrabtree
It was dangling from a loose zip tie on the water heater with the wires squeezed between the water heater and the sofa frame. It is now screwed to the floor.
Screwed to the floor will certainly keep it from dangling loose... but... if you screwed it to the floor anywhere near where water from a tank leak or plumbing leak could pool on the floor, it will ruin the control board.
The factory sticks them to to top/side of the tank to keep them off the floor but the tape often doesn't stick for long. I've always used better tape or screwed them to a wall/upright support.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
