Old 08-14-2022, 03:04 PM   #1
LRCrabtree's Avatar
Send a message via ICQ to LRCrabtree Send a message via Skype™ to LRCrabtree
What is this? (Suburban module board for water heater)
Anyone know what this electronic device is? It is connected to the water heater.Click image for larger version
Larry
W5JVJ
LRCrabtree is offline   Reply With Quote
Old 08-14-2022, 03:08 PM   #2
Berkshire 390QS
NO3putt's Avatar
It's the controller for the hot water heater.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 08-14-2022, 03:47 PM   #3
Kanadian Kamper
kenandterry's Avatar
Yup…it’s the controller. Best to not have it moving around much. Tape it down if there’s room.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
kenandterry is online now   Reply With Quote
Old 08-14-2022, 05:53 PM   #4
LRCrabtree's Avatar
It was dangling from a loose zip tie on the water heater with the wires squeezed between the water heater and the sofa frame. It is now screwed to the floor.
Larry
W5JVJ
Old 08-14-2022, 06:46 PM   #5
wmtire's Avatar
It is the module board for a Suburban water heater. It controls the function of the propane mode of heating.
They come loose like that from the manufacturer. It is up to the final installer where to mount/attach the module board after installation of the water heater . You may find them loose like yours was, screwed to nearby frame, or many times just stuck to the styrofoam insulation on the tank itself with double-sided adhesive tape.
2011 Flagstaff 831 RLBSS
Stayed up all night trying to remember if I had insomnia or amnesia
Old 08-14-2022, 06:54 PM   #6
wmtire's Avatar
One more thing, it is good that you know what/where this module board is located for future reference. These module boards can/do go bad and are easy to replace now that you know where yours is. This thread link below may help troubleshoot a module board problem in the future if you encounter your propane mode of heating not working correctly.
https://www.forestriverforums.com/fo...ml#post1906134
I am also going to edit your thread title somewhat
Old 08-15-2022, 09:08 AM   #7
LRCrabtree's Avatar
Much appreciated!
Larry
W5JVJ
Old 08-15-2022, 09:20 AM   #8
Screwed to the floor will certainly keep it from dangling loose... but... if you screwed it to the floor anywhere near where water from a tank leak or plumbing leak could pool on the floor, it will ruin the control board.
The factory sticks them to to top/side of the tank to keep them off the floor but the tape often doesn't stick for long. I've always used better tape or screwed them to a wall/upright support.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
water heater, suburban, water, heater
