09-10-2017, 08:13 PM
Where to buy these plumbing parts ?
Hello. I have a leak and I need to replace both sections of the black PVC in our 2013 Rockwood 1940 LTD Popup camper. It's the plumbimg that goes from the sink to the outside of the camper (grey water). There is a tiny crack in the connection on the trap (see red arrow in photo) and the two pieces are cemented together so I have to replace both of them. I wasn't able to purchase them a local camping store or at Home Depot.. Any idea what parts I would need to order and what website would have them ? I don't see these parts on the parts list that came with our camper. Thanks. Pam
09-10-2017, 08:14 PM
It should be a standard P trap that you can find at any hardware store.
09-10-2017, 08:26 PM
It's going to be whit at home depot or any hardware store you just need to know the dia. More then likely 1 1/4
09-10-2017, 08:28 PM
Recently new!
A liberal application of black pvc cement inside and out, made for black plastic will get you by for a while. Just avoid the threads. If you can find either an older hardware store near a mobile home community or a mobile home supply store.... My pop up did the same thing. I forgot to add a bit of anti freeze in the sink trap one winter. I figured it out my first trip of the year, nobody had the right diameter, so I used the glue trick. Lasted thru a whole summer.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
09-10-2017, 08:29 PM
take the black plastic part to a good, large hardware store where the hired help there is always much better then the big box stores... I would bet you can get pieces that will fit together to replace that section
2014 Shamrock 183
09-10-2017, 09:07 PM
Thanks all for the replies. I brought the pieces with me to ACE hardware and Home Depot. Both had the trap section of the PVC but not the section that exits the camper with the threads. What they had with the threads I need was too short (the threaded section was too short). See the section at the bottom left of the photo I attached. Good idea about the black pvc glue but I am hoping to replace them so I don't have to go through his again. Thanks. Pam
09-10-2017, 09:24 PM
DW's 401(k) Plan
If you've gone through all that, I would contact Forest River and see about purchasing it directly from them.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
09-10-2017, 10:31 PM
Did some searching and couldn't find anything that looks like that long threaded part.
Just a thought: You MAY be better off in the long run to get something "standard" that will connect the shorter version you did find with whatever it that the longer version goes into. Then if you have future problems, you'll be able to find the parts.
2011 Traverse LT, 3.6L, FWD
09-10-2017, 11:17 PM
I think the long threaded part is called a bulkhead fitting. Search "1 1/2 pvc bulkhead fitting" on Amazon.
If you use glue, try thick or gel super glue.
RV manufacturers like to use fittings that no one else has ever seen, including RV dealers (especially RV dealers).
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
09-11-2017, 06:19 AM
Thanks for searching. Good point. The long threaded part is what goes through the wall of the camper tonthe outside and then you screw the grey water cap onto it. It has to be long enough to get through the wall of the camper. What they had in the big box store only had about a 3rd of the amount of threading. Going to swing by Campers Inn today to see if they can help. I am also waiting for Forest River to answer my email. Thanks all for taking the time to respond !
09-11-2017, 06:22 AM
Ahh... that might help Andy. I'll try searching Amazon for "1 1/2 pvc bulkhead fitting. Thanks ! Pam
09-11-2017, 10:15 AM
Here's one:
https://www.amazon.com/Lifegard-Aqua.../dp/B0002HBL9A
09-11-2017, 11:58 AM
Here's a method to make your own based on parts that are available at the big box hardware stores. Good luck!
An Improvised PVC Bulkhead Fitting for Liquid Storage Tanks
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
09-11-2017, 12:06 PM
this came up a while back, but I don't remember the results... I think Yooroo had the answer. Maybe he will chime in.
I will try to find it
2017 Puma 297RLSS
09-11-2017, 12:15 PM
Here its is... no solution given other than the dealer
http://www.forestriverforums.com/for...-139400-2.html
2017 Puma 297RLSS
09-11-2017, 01:04 PM
Pam,
Try calling Customer Service for the manufacturer of your camper. Sometimes they have unique proprietary parts to fit particular applications.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-11-2017, 01:50 PM
Try McMaster.com
09-11-2017, 02:09 PM
If the threaded end in not long enough, could you get a shorter one and add an extension to get out of the tt.
09-11-2017, 06:39 PM
I had a somewhat similar situation with the outside shower header assembly on my old Sprinter years ago & ended-up "coating" the crack with JB Weld. It was still holding when I traded the trailer.
Rick & Kem
2019 RAM 2500 6.7 Cummins Diesel
2017 Rockwood 2606WS
09-11-2017, 06:48 PM
Most of the better trailer supply stores I believe carry those parts.
We have several here in San Diego that carry all of the lightweight faucets and fixtures piping excetera.
M-Bob
