Old 04-15-2024, 10:40 AM   #1
Which pressure washer to clean out black tank?
I just bought a pressure washer kit to clean out my 150' french drain in my back yard.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Got me thinking I could shove it down the toilet and clean up my black tank. Scared my gas pressure washer might just blow everything apart. Choices of pressure washer:
1. Gas 3,200 psi and it is a beast
2. Electric 2600 psi
3. Electric 1100 psi
All are equally easy to use but thought I might go with the #2 instead of the beast.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 8400Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is online now   Reply With Quote
Old 04-15-2024, 10:45 AM   #2
go with the beast . most come with different nozzles for wider spray and less force when needed . then when it comes to cleaning the driveway you will have the power needed . imo
MR.M is offline   Reply With Quote
Old 04-15-2024, 10:46 AM   #3
Oops, I wasn't clear. I already own all three of these pressure washers.
Old 04-15-2024, 11:09 AM   #4
Choose one and use it.
Bob
Bob K4TAX is offline   Reply With Quote
Old 04-15-2024, 11:24 AM   #5
D W
D W's Avatar
A pressure washer is a little bit of an overkill, besides you only be able to shoot straight down. Get one of these:
https://www.walmart.com/ip/Camco-401...5?from=/search
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 04-15-2024, 11:27 AM   #6
My pressure washer has a 3 ft long wand with about a 45-degree bend.........that was after I accidentally stepped on it. I don't recommend the modification. Otherwise, it works great for almost all applications.
Bob
Old 04-15-2024, 11:29 AM   #7
I have that kit I linked from Amazon that has a few different multi-directional nozzles with it.
Old 04-15-2024, 01:23 PM   #8
I don't see an end that will only shoot sideways and not potentially back towards you. Be prepared for getting sprayed, and hopefully just with clean water.
2021 Ram 3500 HO DRW Megacab 4wd 3.73
2022 Riverstone 42FSKG | GenY Executive 6.5k
Airlift 7500XL Airbags w Wireless One Compressor
darrellr is offline   Reply With Quote
Old 04-15-2024, 01:32 PM   #9
Instead of going down the toilet, try this approach:
  • Empty the tank.
  • Crawl under the trailer.
  • Inspect the black tank and determine on which side of the tank the sensors are located. They are easy to spot.
  • Pick a wand/nozzle that will spray in that direction when inserted in the black tank outlet.
  • Take off the drain cap.
  • Open the valve.
  • Insert nozzle and spray.
Larry
Larry-NC is offline   Reply With Quote
Old 04-15-2024, 01:33 PM   #10
The one nozzle only sprays backwards to draw the hose in further. And it rotates.
Old 04-15-2024, 01:34 PM   #11
  • Empty the tank.
  • Open the valve.
I could go in the out hole with the hose and nozzle but that's a recipe for poo face.
Old 04-15-2024, 01:40 PM   #12
Ok, that is not clear from the link, photos, or the description that says rear nozzles lol. Best of luck staying dry and clean. I do see where it shows then pushing it down and then sideways. Maybe that helps.
Old 04-15-2024, 02:04 PM   #13
And...
It's still worthwhile to know where the sensors are, even if you are putting a wand down the toilet, so you know which way to face it.
Larry
Old 04-15-2024, 02:10 PM   #14
I ran across a video like this (maybe the same but it seems it was last year sometime). Maybe it would help?
Old 04-15-2024, 02:31 PM   #15
D W
D W's Avatar
A whole lot of talk, talk and more talk. Just get to the point!
By the way, it's not advisable to perform a Fred & Ginger routine on your roof.
2016 Salem 27RKSS
Old 04-15-2024, 02:42 PM   #16
I am not putting a wand down the toilet. I am putting a hose with a nozzle on the end down the toilet. It's a snake like used in plumbing.
Old 04-15-2024, 05:09 PM   #17
Go with the 1100. Dump and flush tank if you have a flush. Get you one of the following and put the pressure washer in the small cam up to the tank, wrap a cotton rag around the hose and push it in and out. When done pull the hose just far enough that you can close your dump valve, have a tub of some sort under the small cap during this process. Once you remove the pressure washer hose and drain what's in the pipe between the dump valve and the cap, hook up and dump.
Giboneys is offline   Reply With Quote
Old 04-15-2024, 05:11 PM   #18
https://a.co/d/0EBSSH0
Old 04-15-2024, 06:41 PM   #19
CAUTION
I wouldn't use a pressure washer of any type in my black tank.
If you have a black tank flush, that's plenty. Simply run the black tank flush for 30 to 60 seconds and give it a rest. After 10 to 15 minutes, time enough for solids on the tank wall to emulsify, run it again. Use a clear dump adapter to monitor the output. If you notice that you dislodged a significant amount of solids on the second pass, wait a few more minutes and hit it again.
If you don't have a black tank flush, use something like this tank rinser.
Household water pressure is about 60 PSI +/-. The rinsers might create the illusion of a jet of water at slightly higher pressure, but physics says not. The increased velocity of a small nozzle at 60 PSI is more than enough cleaning power. I may be alone in this opinion, but there's not a chance I would put the wand of a pressure washer down my black tank at 1100 PSI +. I use my pressure washer to strip paint and remove stain on decks. While the plastic tank might be fine, I can't imagine the sensors and seals in the tank tolerating that kind of pressure. But that's just my opinion.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
Old 04-15-2024, 07:40 PM   #20
Yeah, I'm thinking that pressure washer nozzle thrashing about in the black tank might take out a sensor. I have a tornado installed and don't have any issues with sensors so may just leave well enough alone.
black, black tank, pressure, tank
