10-27-2020, 03:07 PM
Why do I really want or need this?
There I was minding my own business and Amazon wants to sell me this.
(SEE THE PICTURE)
My thoughts:
Why do I need this?
What adapter do I need to make the air fitting I have on my compressor stay attached while I blow the water line clear?
Will my wife hold the air fitting I have in place for me?
Can I use my bicycle hand pump with this to clear the air lines?
How much would I have to pump to clear the lines?
Does anyone else have this and I’m the only one not smart enough to see the benefits?
2006 Forest River Georgetown 340 TS
10-27-2020, 03:14 PM
Yes we have one.
We carry an air compressor to top up tires as needed.
That pump will pressurize the water system for winterization thru that fitting.
Half a gallon of antifreeze for the drains and water pump instead of three gallons to do it the other way.
10-27-2020, 03:21 PM
(SEE THE PICTURE)
My thoughts:
Why do I need this?
For that you would probably need a locking air chuck. At least if you want to do it by yourself and not need someone to stand there and hold it.
Although one like this works soo much better.
https://www.amazon.com/Camco-Brass-C...e%2C150&sr=8-5
10-27-2020, 03:23 PM
I have the Camco plastic version I got at Walmart. Cost about $3.
10-27-2020, 04:06 PM
X2.
10-28-2020, 01:18 PM
(SEE THE PICTURE)
My thoughts:
Why do I need this?
Hello,
I would recommend the one in the link below. It allows you to connect the air compressor quick connect directly to it so you can go about opening faucets to vent out the water. The one you asked about requires you to hold on the air chuck so you can't leave it unattended.
Rick
https://smile.amazon.com/Winterizing...NsaWNrPXRydWU=
10-28-2020, 01:28 PM
Triglide
You should also use a regulator on the air line so you can cap the pressure off at 35psi or you could do damage to the pump and water line fittings as they are usually plastic
Bob & Deb
2013 Georgetown 335 DS
10-28-2020, 01:34 PM
Originally Posted by hunterrick
Hello,
Rick
I just Amazon ordered a similar unit without the hose section. I like having the valve to control the air from a standard compressor.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
10-28-2020, 01:38 PM
Used one, for years to blow out water out of the lines. Mine was 99 Cents at my dealer a couple oy years ago.
Open faucets and low piont drains and blow compressed air through them.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
10-28-2020, 02:01 PM
Air Chuck
I made an adapter with a MIP hose to 3/4" brass adapter, reducer coupling and an air hose chuck. It also works to blow out me sprinkler system too. I set my compressor to 35-40 psi and let it run. So far so good.
2017 F.R. Vibe 251RKS
2018 Ford F-350 Power Stroke Diesel
1931 Ford Deluxe Roadster
1976 Triumph Spitfire 1500
10-28-2020, 02:23 PM
I’ve used a similar one with an air pressure regulator. Set to 40 and haven’t had any problems blowing out the water lines.
10-28-2020, 04:25 PM
Winterizing
I use the same one Hunterrick linked, standard air hose quick connect. You want volume air VS high pressure.
10-28-2020, 05:20 PM
I made one to fit a quick connect to my compressor and set the output of the compressor to about 35 psi also have a shutoff valve with it.
All from truck stock, as I am a pipefitter/hvac mechanic
2018 sunseeker 2860DS
10-28-2020, 06:01 PM
Hello,
Rick
That example is excellent! I built my own version of that in plastic parts so mine was about $10 dollars. I would have bought something like that but I ended up there anyways. Thanks for the link
10-29-2020, 06:51 AM
(SEE THE PICTURE)
My thoughts:
Why do I need this?
no use the male end Of you quick disconnect and it is a 1 man job
10-29-2020, 09:46 AM
I think that's the one I have as well. A short piece of vinyl tubing and connects to blow gun from air compressor
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
10-29-2020, 12:00 PM
Originally Posted by Iwritecode
That’s exactly you the one I use. I set my air compressor to 40-ish lbs since that’s what the water regulator allows. Just plug it up and open valves one-by-one until all the water is out. I can’t imagine having to hold the chuck in place by hand.
10-29-2020, 12:18 PM
(SEE THE PICTURE)
My thoughts:
Why do I need this?
I'm in Texas and not to concerned with freezing RV water lines but I do use the adapter you show and open all the outlets and hand actuate a bicycle tire foot pump to clear the lines as much is needed. I have checked afterwards and it does a very good job of clearing the residual water out.
11-02-2020, 07:31 PM
That looks like it has a tiny passageway for the air.
I just made one. The local hardware store or HomeDepot has all the parts. Just remember to dial back the air pressure before you hook it up.
Bob
11-02-2020, 09:54 PM
(SEE THE PICTURE)
My thoughts:
Why do I need this?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
