The vent hose should be higher than the water tank, to prevent it from syphoning. On my Flagstaff, the vent hose runs right beside the filler tube, which works very well. There is also a drain tube that runs out under the tank area, that is opened/closed by a push/pull type valve, to allow draining. Hope this helps! Randy
