Old 09-30-2019, 10:41 PM   #1
Winterization question, running antifreeze through water pump
I just bought a 2019 grey wolf 26dbh a couple months ago and am trying to winterize it. Im pretty sure the dealer said i can just put a line into the antifreeze jug as I would like to avoid putting antifreeze in my FW tank.
I am attaching a photo of the water pump and lines, do I need to add a winterization kit? And if so, what line do i attach it to?Click image for larger version
Rockytop04 is offline   Reply With Quote
Old 09-30-2019, 11:00 PM   #2
Your bypass valves are by water heater. Show us that picture if you can
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 09-30-2019, 11:07 PM   #3
I already bypassed the water heater, im wondering about how to pump the antifreeze through the lines.
For example the attached picture. My dealer acted like there Click image for larger version
ID:	216334was a factory tube already installed to put into the antifreeze jug but I dont believe that is the case.
Old 09-30-2019, 11:14 PM   #4
That looks right to me There should be a valve there to turn then turn on pump to pump in
2015 F 150 max tow
Old 10-01-2019, 07:16 AM   #5
For example the attached picture. My dealer acted like there Attachment 216334was a factory tube already installed to put into the antifreeze jug but I dont believe that is the case.
I have a Coachmen Apex and there is about a 3 foot section of hose attached to the pump with a 1/4 turn valve on it and 1/4 turn valves on the pump/FW Tank suction line. I can grab the hose and insert it into the jug of RV A/F and open that valve, close the valve to the fresh water suction, close the valves to the water heater and open the water heater bypass... and then hit the bathroom wall switch to suck the fluid in and push it around my system. Picture attached.
Name:	2020 Apex Ultralite 289TBSS.jpg
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 10-01-2019, 07:23 AM   #6
From your photo it doesn't appear you have a winterization valve/hose.
It is hard to see everything on the suction side of the pump but it appears the fresh water supply line comes out of the floor (at the big gob of foam) and attaches directly to the suction/strainer at the pump with nothing in between.
That would be where the winterization valve/hose would be.
Days Camped: '17=30 '18=51 '19=58 '20=51
Old 10-01-2019, 07:26 AM   #7
Flybob's Avatar
The valve that selects either FW tank or winterization hose should be on the input side of the pump just before the small black strainer on the right hand side of the pump. I do not see a winterization valve in your photo. It is possible that the valve is further down the clear line in the very back right that goes into the black sealer. If not it is very simple to add one for about $15.00. You are correct in that you do not want to put antifreeze in the FW tank as it is difficult to get out and requires many gallons to be effective. Try to follow the line from the right side of the pump through the floor and look for a valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-01-2019, 07:41 AM   #8
Brake is on left
The Evil Twin's Avatar
I have a different model, but this may help you out:
Under the trailer, there is a T valve (diverting valve) in the FW supply line to the pump from the tank. After I drain everything, I put all the low point plugs back in and turn the diverting valve to close off the tank and open up the drop leg. I fabbed an adapter to go from the threadded fitting on the drop leg to a nipple then a hose (3/8 ID if I recall) and drop the hose in the antifreeze jug. Actually, I just filled a 5 gallon bucket with antifreeze. Then I'll just turn the pump on and open up the furthest faucet. The pump sucks it right out of the bucket.
The Evil Twin is offline   Reply With Quote
Old 10-01-2019, 12:58 PM   #9
x2 on what 5picker said.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 10-01-2019, 04:37 PM   #10
Most newer pumps and rv's have quick connects on both sides of the pump. For winterizing, our MH came with a 3 foot length of hose that has the male, quick connector on one end. I just have to disconnect the suction line from the pump, connect the winterizing hose, put the other end in a gallon jug of antifreeze and the gallon disappears in very short time. Then switch back to the regular suction hose.
markb422 is offline   Reply With Quote
Old 10-01-2019, 08:32 PM   #11
Semper Fi
almcguire is offline   Reply With Quote
Old 10-01-2019, 09:29 PM   #12
Adrian Gordon's Avatar
Can we see a picture of freshwater fill/city water/winterizing connections on the outside of your unit, please?
2018 Coachmen Leprachaun 210RS with DW, a German Shepherd and the cat.
Adrian Gordon is offline   Reply With Quote
Old 10-01-2019, 10:32 PM   #13
Recommend a different method
We used to use antifreeze for winterizing: it's a good choice if one plans on stowing the RV for half a year. However, about three years ago, my wife and I began to use the "blow down" method, which made it much easier to head south for a few days during the winter for camping.
Basically, we went to Harbor Freight (any place such as Lowes will work) and bought a small compressor/tank as well as the fittings which would adapt the compressed air line to the city water inlet on the trailer. We then used the compressed air (at about 40 psi) to blow the water out of all the pipes.
When we were done, the water pipes (and HW heater) were basically empty: the little bit still in the pipe was harmless.
Then, when we want to head south for a weekend, we just hook up the water to the "city connection", and all works. After camping, we blow the water out of the lines again: a very smooth process.
When expecting a long, hard freeze, we still pour some RV antifreeze into the black and grey tanks. These are probably not needed, but do provide some small extra insurance.
KellyG is offline   Reply With Quote
Old 10-01-2019, 10:49 PM   #14
I have a hot and cold low point drain, if I just drain out the water there will I still need to winterize? It gets down to 27 at night but warms up to the 50ís during the days where I keep it.
Lostcoast is offline   Reply With Quote
Old 10-01-2019, 11:31 PM   #15
Thanks for all the replies everybody, I will get some better pictures tomorrow of the inside and out to get a better idea of what things look like.
I considered blowing the lines out but we get -40 to -50 in January and February on occasion so I feel the antifreeze is my best option.
Old 10-02-2019, 06:00 AM   #16
Brake is on left
Probably would be ok....probably. Even when you pop the low point drains there is still a lot of water in there. I estimate 2-3 gallons is what I pushed out. Lets say the low temp in your area got to 25. It isnt like it was 25 all might long. It is probably only below freezing for a couple hours tops. The inside of your rig is less likely to fall to 25 because of the heat that built up during the day. Thing is, records can always be broken and I wouldn't want to get taken by surprise. It would be the worst to realize in the middle of winter that I needed to go pump AF in during a cold snap.
Old 10-02-2019, 07:10 AM   #17
Here are several more pictures I took
ID:	216426Click image for larger version
ID:	216425Click image for larger version
ID:	216424Click image for larger version
ID:	216423Click image for larger version
Old 10-02-2019, 07:19 AM   #18
Open or closed underbelly ?? In post #8 EvilTwin described about the same way I do mine. I have open under belly. Pump line goes to TEE on bottom of FW tank. I disconnect the pump line, have a line made to screw onto pump hose, I fill a 3 gal bucket with AF, put end of hose in bucket, turn on pump and start doing faucets....Inside and Outside.
TheWolfPaq82 is offline   Reply With Quote
Old 10-02-2019, 08:24 AM   #19
Brake is on left
Looing at your photos, the only way the pump will pull AF into the trailer is if there is a T fitting underneath the floor. The suction side (with the little clear bowl) only has one line and it goes through the floor. From what I can see, the suction line has a crimp clamp that is not as easy to remove as a screw style clamp. I'll bet ya a donut that it is under the rig.
Old 10-02-2019, 08:32 AM   #20
The bottom is enclosed, so I dont have much access or able to see much under there unfortunately. I had found my plug to drain the FW tank, so Iíll crawl back under and take a look after work.
antifreeze, pump, water, water pump, winter
