Old 10-27-2016, 08:45 PM   #1
Winterizing
We bought our TT new and have never used fresh water tank or water pump. Always have had a city connection. Is there some way to winterize through the city connection instead of running through the water pump?
Sfogle is offline   Reply With Quote
Old 10-27-2016, 08:46 PM   #2
SeaDog's Avatar
You can do that by using low pressure air instead of antifreeze
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-27-2016, 09:13 PM   #3
WFD
Are you just trying to avoid using the antifreeze? Because even though you never used the pump, you say you bought new, your dealer probably(should have) run water through it during their PDI. I certainly would not assume the pump is dry, and would not risk any residual water being in there and subject to freeze. Far better off to just use the antifreeze. Better safe than sorry as the saying goes.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-27-2016, 09:31 PM   #4
Didn't think of that WFD. I'll go ahead and use the pump. If nothing else I can make sure the pump works. Thanks
winter
