mr dan has it exactly!
the red valve (along with some hidden check valves) is used to bypass the water heater.
the white valve is in your water pump's input suction hose. in the normal position it will draw from the fresh water tank. if the winterize position it will draw from that hose in the picture. put that hose in a jug of antifreeze and let the water pump draw it up and pump it throughout.
when winterizing remember to:
remove water filters prior to pumping antifreeze
drain all tanks
drain water heater
remember any plumbing lines for: outside shower, washer, refrigerator / ice maker, black tank flush
pour antifreeze into all drains, traps, toilet
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
