Originally Posted by rwriley1053
So where is the inlet ? Is it coiled up in the corner somewhere ? I could try to send my Grandson to find it
I can’t find a photo of the intake on your particular unit, but you can send your grandson outside and around back to the passenger side rear corner, down low on the very back of the coach. The antifreeze inlet port is one of the three inlets, next to your city water inlet and your black tank flush. You screw a short section of hose into it, with the other end stuck into a gallon just of antifreeze. When you’re ready to winterize, you’ll turn that valve (the one the dealer told you about) back to the winterize position, which will change where the water pump will draw from…. Instead of sucking water out of the fresh water tank, it will draw from the winterizing port out back (and, subsequently, the antifreeze jug you setup back there).
Hope this helps!
