Old 10-24-2020, 11:37 AM   #21
Tundra 2014
Winterizing
The reason I limit pressure is so I can leave the compressor running and go from valve to valve opening and then closing faucet-one at a time.
Tundra 2014 is offline   Reply With Quote
Old 10-24-2020, 11:44 AM   #22
PhD, Common Sense
I don’t know about air, but at 45 psi the water pressure drops only about 5 psi when I open a single faucet. Air probably drops more, but I don’t know.
Still, for the reason cited in Tundra’s post, having nothing open from time to time during the process, I limit my air pressure to 45.
eye95 is offline   Reply With Quote
Old 10-25-2020, 06:49 AM   #23
Originally Posted by txredfish View Post
100 PSI would be too much air pressure on the lines. I am not how much PSI your lines can handle. I use about 40 PSI on mine and it is plenty to blow out the lines. I assume you can regulate the pressure on the pressure on the compressor you are looking at.
X2! Used the air pressure method with anti freeze in the p-traps the last couple years with no problems. Just keep your compressor pressure low. I keep it between 30 and 40 psi. Had a friend blow off a couple line fittings once because he didn't manage the air pressure
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
Roberte52 is offline   Reply With Quote
pressure, winter, winterizing
