03-25-2021, 03:07 PM
Word to the wise
When replacing the probes on your black tank, consider that it might contain some residual.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
03-25-2021, 03:15 PM
“Residual what...” he asked with a knowing grin
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
03-25-2021, 03:23 PM
Trailer Park Supervisor
no pics?
Yes, I drink the water!
03-25-2021, 03:50 PM
Yuck!
Nitril gloves and a large bucket required for that job.
2015 Dynamax REV 24TB class C
03-25-2021, 03:55 PM
code.org
Need we ask how you know this?
Sounds like a good story.
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
03-25-2021, 04:00 PM
Ewwww.... icky-poo.
Another job that makes you glad your job isn't changing them at an RV service center?
"We do not quit playing because we grow old. We grow old because we quit playing." ~ Oliver Wendell Holmes
2021 Wolf Pup 16FQ
2005 Toyota Sequoia
03-25-2021, 04:02 PM
Fortunately just a trickle and I was able to get out of the way. But I did the black tank before the gray tank and the gray tank is downhill, so I'm not doing the gray tank today.
03-25-2021, 04:04 PM
Originally Posted by Reverse_snowbird
Yuck!
Taking a bath in hand sanitizer
03-25-2021, 05:04 PM
Wait. Your RV is a year newer than mine and you're doing that already??
03-25-2021, 05:17 PM
Now you know why a Plumber charges $100+/ hr when he comes to your house.
2016 Salem 27RKSS
03-25-2021, 05:30 PM
If you read my response in another thread about spending money on our trailer, it's my version of a hobby car. The possibilities of spending money on it are endless.
I'm replacing them while I have the bottom off the trailer for other reasons. I really don't want to take the bottom off again, and we've already gotten wrong information from the level gauges. Hopefully the Horst probes will be better. We'll see.
03-25-2021, 06:12 PM
I think I'm up to 6,500 bucks spending on a 17.5k trailer, lol, didn't see your other thread. Are these probes engineered differently than OEM? Mine work fine till things get city in the tank! Then don't work again properly till a good tank flush.
03-25-2021, 07:39 PM
OEM tank liquid levels are measured with 4 electrical sensors on the wall of the tank. They're essentially the head of a bolt, held in the wall of the tank with Well nuts. Conductivity between them determines the tank level. Well nuts are rubber grommets of varying depth with a bolt through them. They're compressed by tightening a nut. The grommet expands on the back side and secures the Well nut in place.
The probes are wired to the control panel. The lowest level probe is the common wire and 3 others are increasingly higher on the wall are associated with the 1/3, 2/3 and full lights on the control panel. The weakness is that solids and paper stick to the wall, short out the probe and give bad information. Gray and fresh tank probes are the same and, despite the lack of solids, condensation on the wall of the tank shorts them out.
Horst Miracle probes (now owned by Valterra and marketed as Valterra Horst Probes) address the problem by putting the probe farther out into the tank and, in the case of the black tank, they're shrouded on the top. The theory is the shroud prevents solids from shorting the probe and being farther out into the tank prevents wall condensation from doing the same. Some people report success; others scoff. I guess I'll find out.
The pic below shows the black tank probe with the shroud and the fresh tank probe without. You have to be sure the black tank probe is installed with the open side down. Otherwise, it acts as a scoop, not a shroud. The bolt on the outside has a flat spot which indicates which side is up.
I installed black tank probes in all tanks because they were cheaper at the time I bought them. Shrouded probes will work in fresh and gray tanks but probes without shrouds won't work in black tanks. They'll just catch all the toilet paper floating around.
Edit: changed pictures
03-25-2021, 07:44 PM
Just as confused as you
My guess is beer.
Richard & Jill
03-25-2021, 07:58 PM
Good explanation. I figured condensation induced errors. Now I know why they tend to show liquid present even when tank is empty sometimes. I have never had them erroneously show tank is empty when it is full, now I know why.
03-25-2021, 08:55 PM
Originally Posted by Scrapper
My guess is beer.
Close!! It's really USED BEER!!!
Brian & Becky
2018 Avenger ATI 27RBS
03-26-2021, 09:28 AM
I'm smart enough to know that black tank tank probes never register properly, so I wouldn't do the job at all.
03-26-2021, 10:06 AM
Many users report that Horst probes work well. I'll let you know.
03-26-2021, 10:14 AM
If I'm ever an in a position to upgrade my tank monitoring system, I'll go with the SeeLevel system, and do away with probes. Just waiting for a time when I have to pull down the under belly for some other reason.
2017 Rockwood Windjammer 3006WK
03-26-2021, 10:51 AM
Am I correct in assuming you are referring to the black fiber board that seals the guts of the underside of the floor? I have been looking at that lately and trying to figure our how that would come out and if I would ever be able to ever get is reattached properly.
