Old 07-03-2022, 09:19 PM   #1
12.5v at New Battery When Plugged into 110V/ House
Hi All I Have a 2006 forest river Flagstaff Classic Super Lite 5th Wheel We Bought Last Year.
I bought a New Marine 12v Battery today and Installed it.
I Put a Volt Meter on it while Plugged into the 110v House Plug, I'm only Getting 12.5 Volts.
Is the Onboard Battery Charging Output Just a Tiny Bit compared to a Cars 13.6 - 14.6 Volts from My Automotive Training Years ago ??
Timmy from CT
French69ssrs is offline   Reply With Quote
Old 07-03-2022, 10:01 PM   #2
Nope. Your converter should be outputting 13.4 to 14.6 volts. Things to check:
Battery disconnect switch
Resettable 12 volt circuit breaker
Reverse polarity fuses in converter
AC circuit breaker for input to converter
NavyLCDR is online now   Reply With Quote
Old 07-04-2022, 07:56 AM   #3
Also- make sure the converter is getting 120v power. Not unusual for outlet at house to be dead, extension cord to be bad, or power inlet to be faulty.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
110v, battery
