Old 07-03-2022, 09:19 PM   #1
12.5v at New Battery When Plugged into 110V/ House
Hi All I Have a 2006 forest river Flagstaff Classic Super Lite 5th Wheel We Bought Last Year.
I bought a New Marine 12v Battery today and Installed it.
I Put a Volt Meter on it while Plugged into the 110v House Plug, I'm only Getting 12.5 Volts.
Is the Onboard Battery Charging Output Just a Tiny Bit compared to a Cars 13.6 - 14.6 Volts from My Automotive Training Years ago ??
Timmy from CT
French69ssrs is offline   Reply With Quote
Old 07-03-2022, 10:01 PM   #2
Nope. Your converter should be outputting 13.4 to 14.6 volts. Things to check:
Battery disconnect switch
Resettable 12 volt circuit breaker
Reverse polarity fuses in converter
AC circuit breaker for input to converter
NavyLCDR is offline   Reply With Quote
Old 07-04-2022, 07:56 AM   #3
Also- make sure the converter is getting 120v power. Not unusual for outlet at house to be dead, extension cord to be bad, or power inlet to be faulty.
110v, battery
