14.1 and 14.0 are within the margin of voltage meters not designed to monitor nuclear reactors. Good enough. 14.05v will probably bounce between 14.1 and 14.0. Remember the "Significant digit" from high school physics? Unless you're measuring to 2 or 3 decimal places you can get what you describe.
Driving voltage around 14.1 sounds right as the alternator is charging the battery(ies) and needs at least a volt higher charging voltage than the battery has.
Electrical loads will lower the voltage. The more load the lower the voltage can drop.
-- Chuck
