Hello fellow campers. I have a common problem with a twist. The 12v dc powered items do not work from the battery. I checked from the battery to the outpost of the breaker. The voltage of the battery is 12.6 and at the out post of the breaker the voltage is 11.8. Is this a problem? If not, where to next? Thanks a lot.
People will be able to help you more if you provide the year, make, and model of your RV. New RV? New problem that wasn’t there before? Has the battery been recently disconnected or removed?
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
Turn something on and see if it is still 11.8 - if it goes to zilch and the other side is still 12.6 the breaker is bad.
Sounds like your batteries are ok...
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
