12V Interior lighting issue
Newbie poster here.I have a 2017 Grey Wolf 23DBH that has had basically zero issues over the last 4 years. Last weekend, while connected to shore power we lost power due to rain storm for about 5 hours. The middle row of lights down the center of the living room are controlled by a separate switch on the control panel by the door as well as the push on/off functionality of the lights. All worked fine that evening on battery power and I turned off the lights at the switch when we went to bed not knowing when the power would come back on. Shore power came back on at midnight and apparently tripped the GFCI outlet in the bathroom. In the morning I tried to turn on that center row of lights at the switch after I reset the GFCI outlet and nothing happens. Tried the push on/off on each of them as well and still nothing. All other lights work fine by using the push on/off button on the light. Is it possible the switch controller went bad or is there a separate 12V fuse location for that center row of lights somewhere?
