Old 10-24-2020, 06:19 PM   #1
12v Lights Flickering
In my 2007 Sunseeker 3100SS, sometimes when I have significant 12v power usage, whether I am on shore or generator power, the lights flicker, apparently due to the voltage change from cycling of the converter between charging and not charging the batteries. Just wondering if anyone else experiences this and whether it is abnormal for the converter to deviate from constant charging.
Underdog is offline   Reply With Quote
Old 10-24-2020, 09:07 PM   #2
NMWildcat's Avatar
Start by checking your batteries (load test). If they are good, check your converter. Also check all connections. Lots of videos on how to perform all the above suggestions if you aren't familiar.
Scott and Liz - Southern NM
Old 10-24-2020, 09:44 PM   #3
SlowrideHD's Avatar
It seems that flickering 12v lights soon foretell of converter failure.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 10-26-2020, 01:15 PM   #4
Kirk S's Avatar
Not sure from your post if all lights flicker or just some.
Our issue was from defective LED lights that were factory installed.
Command Electronics was nice enough to send replacement guts for me to swap out.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 10-26-2020, 01:31 PM   #5
Could be fluctuations in the converter output voltage but as Kirk S mentioned, we had just TWO lights that flickered and they were bad lights. Once I replaced those two lights, no more flickering.
Days Camped: '17=30 '18=51 '19=58 '20=98
light
