Check the DC fuse distribution block at the converter. You want to look at the reverse polarity fuses. If either the truck power at the 7-way outlet or the trailer are wired incorrectly (ie, reversed polarity), those fuses are supposed to pop to save the other 12v systems and the converter. Don't just look at them, use a meter to check them.
Also there should be a "Master" DC fuse near the battery. It will likely be a 12v auto-reset or similar "fuse" but it's really a breaker. Some of them will reset automatically, others have a small button on the side that you will need to push to reset them. They look like this either way, the auto reset type will not have the button. 2nd photo is one before they get crudded up with age and is the auto reset type with no button. If you have no power at the DC fuse block near the converter, take you meter and make sure you have power on both sides of the breakers that look like below. You may have 2 or 3 of these, one will be the "master" from the battery to the DC fuse panel, and the others go to high amperage devices (like slideouts, etc...)
