12volt power works on battery power but does not work when pluggedintoto 3amp power.
Hi. I recently purchased a used 2021 Grey Wolf 29BRB. On our first trip out we had a storm and the camp ground lost power for over a day. When it came back on I could only get the 110 power to worked when plugged into the 30 amp power. The 12volt power did not work. When I turned the battery on the 12 volt power would work. As I went through the process of looking for the issue, I decided to disconnect the battery from the terminals on the outside of the camper. About 2 minutes later the 12 volt power kicked on from the 30 amp connection. When we got home I plugged the camper into my house. Same issue. This time I just switched off the battery from inside the camper, but left a light on. A couple hours later I looked out my window and saw that the light had turned on. All the 12 volt power was working while plugged in. Now we are camping again and I have the same issue. Tonight I shut the battery off for a few hours hoping it would kick on, but it did not. Extremely frustrated. I have searched for people with similar problems, but can not find anyone that has this problem where sometimes the power will work. Any help would be appreciated.
