Just a FWIW. I use a 2 watt Coleman solar battery maintainer. Had it for 2 winters now along with use between trips. Does not require a controller. My install has a pair of battery clips always on the battery terminals with the wire hanging out of the battery box. There is a connector to the solar panel. When I park the rig I plug it in and set the panel to catch sun. Has been more than enough to cover the self discharge of the battery.
My battery disconnect does disconnect everything...
Upside, if the panel decides to grow legs, I'm only out about $15. I also considered the 3.5 watt Coleman that runs about $25.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
