Old 05-26-2018, 02:23 PM   #1
20 amp running light/dashboard fuse blows immediately - HELP!
Team...
We are relatively new to RV life. We have a 2017 Forest River FR3 32DS motorhome. It is just over a year old, so I assume the warranty is out for fuse related issues.
Last year, we were on a trip and the 20 amp fuse for the running/dash lights blew. I was able to switch out the fuse and roll on. However, this afternoon, I went to test things out as we are leaving out in a few weeks on a trip and the fuse was blown. I tried to replace several times and it blew as soon as I attempted to turn on the head lights.
I don't have on where to start with investigating. Any help from you experts would be greatly appreciated! Thanks in advance!
braduah is offline   Reply With Quote
Old 05-26-2018, 02:41 PM   #2
A32Deuce's Avatar
Sound like a short in the wiring some where. Try looking at the firewall area where the wires pad through and the area behind the head lamps.
A32Deuce is offline   Reply With Quote
Old 05-26-2018, 03:15 PM   #3
rk06382's Avatar
Originally Posted by braduah View Post
Team...
Get a 12v probe tester to check the wire for a short. Connect it to 12v and see if the probe lights up. Then you can use the probe to follow the wire.
Name:	12v probe tester.jpg
Amazon: OctagonStar 16012 Circuit Tester 6V/12V DC Systems Long Probe Continuity Test Light Car Voltage
I googled '12v circuit tester how to use' and found this youtube example:
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
fuse, light
