Originally Posted by jojogun
I want to extend my shore power cord with a 30 amp RV extension cord I bought at Wal Mart. It has the plugs at either end to plug to the trailer cord and just extend it. I have a 30 Amp pedestal at the house and need the additional length. It's a 25 foot extension. Anyone see any potential problems?
How much power are you going to be drawing at home? Just enough for the converter or running an AC unit or maybe even more up to 30 amps?
More connections in the form of the plugs and connectors on extension cords can potentially lead to overheating. Make sure you keep plug blades clean and shiny with a little sandpaper. Also do no plug in while power is live otherwise the plug blades and contact surfaces inside a receptacle and connector can get pitted and dirty and lead to overheating. As mentioned above, check the cord's plug & connector connection periodically to make sure it's not overheating. Same at the recept. in your home's pedestal.
For those with a detachable cord, you can use a 2nd twist lock type cord and a generator adapter to make an extension cord. We have a spare (30 amp) detachable cord that we keep in case one gets stolen or damaged. Have used it a couple of times along with a generator adapter when we couldn't quite reach a pedestal. Can also be used for putting an autoformer under your RV instead of at a pedestal.
FWIW, the NEC doesn't require a max. voltage drop in a circuit, it only "recommends" a max. of 3% in a branch circuit and 5% total overall for branch circuit + feeder. See here:
http://https://www.mikeholt.com/tech...s-part-one.phpNote the reference to RV Parks which recommends a max. overall voltage drop of 5%. 5% as in 114 volts at a pedestal?? Sorry, but hahaha.
