Old 02-10-2020, 12:24 PM   #1
30A power inlet replacement?
All, I really dislike the power inlet on our new 2020 Mini-Lite. The threads on the lock ring are very fine, and the plastic is really soft. The result is that it takes me 10 minutes to get it threaded right and it frequently cross-threads in the process.
I want a different kind of locking ring. I'd like to replace the power inlet and connector without replacing the entire cord. I do like the fact that the connector is basically a 30A female RV outlet because I could string two together if that ever became necessary. (I don't own the second one so that's a moot point at this time.)
In browsing for replacement connectors and inlets, they're all the traditional twist lock (not entirely a bad idea) and the connectors are all straight. Does anyone know of a source for a 90 degree connector, ideally configured as a 30A RV outlet? The configuration of the inlet would have to match the connector with respect to the position of the pins for the 90 degree angle to work, of course.
Suggestions?
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 02-10-2020, 12:51 PM   #2
Suggestions?
This may fit your needs:
https://smile.amazon.com/Camco-55532...356746&sr=8-26
I have one and it works great. Yes, the threads can irritating at times but I've found that applying a little silicone electrical grease makes them work better.
Having the 90 degree connector at the power inlet makes it easier to move around in tight quarters without the cord sticking straight out.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 02-10-2020, 01:22 PM   #3
Half the time, I don't even bother threading the connector. I just push it in. Of course, that is usually at home since we hardly ever camp where there is power available.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 02-10-2020, 01:43 PM   #4
I screw mine down at home. We get more rain here than you do. As much as 2" per day in the last couple weeks.
2004 Nissan Titan
Old 02-10-2020, 01:57 PM   #5
Check out 30A shore power sockets on boating sites if you are not happy with what you are finding. Defender.com is a good place to start. Boats use the same type of connectors that RV's do.
You probably already know this, but it doesn't hurt mentioning. Turn the threaded ring backwards until you feel a click, then turn it the correct direction. That will help with the cross threading.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 02-10-2020, 05:38 PM   #6
Agreed. The only time mine is plugged in at home is the day before we leave to prechill the fridge.
Old 02-10-2020, 06:06 PM   #7
Thumbs down
And if you do that you create stress and loose connections and you will be here crying about the cheap plugs. ALWAYS tighten the locking ring. It is there for a reason. And there is the possibility for a fire but who cares it's insured right?
Old 02-10-2020, 06:08 PM   #8
google "smart plug" if you must.
Old 02-10-2020, 07:30 PM   #9
I won't cry! Is as firm as the plug that goes into my power panel and that end doesn't have a way to screw on! If that's the worst thing I have to worry about, I will be happy. It's plugged in at home to run the 300W fridge element!
LOL...fire if I don't tighten the locking ring at home...hilarious!!
Old 02-10-2020, 08:34 PM   #10
Don't laugh about the fire. I've seen it happen before. The plug moving in the socket causes small arches which over time raise the resistance in the connection. This in turn heats up the connection. This can get hot enough to ignite some materials. In addition the arching can also ignite some materials.
This happens more on boats since they are not stationary when connected to shore power.
As hilarious as it seems the strain relief is there for a reason and should be used.
I'm done being a nanny now
Hobienick
Old 02-10-2020, 10:16 PM   #11
It's a 300W load while parked in my my driveway. I will survive!
Old 02-11-2020, 01:33 AM   #12
I did, not recognizing the reference to smart home systems. I'm not clear how that relates to a 30A RV connection?
Old 02-11-2020, 01:42 AM   #13
I've got some silicone grease used in chemistry labs. I'll try that.
The 90 degree connector you suggested looks nice. I'll adopt that if I have to use a standard twist-lock connection. The one installed by Rockwood is not a twist lock.
Old 02-11-2020, 02:28 PM   #14
It's on the pricey side but I've considered this:
SmartPlug B30ASSYNT Combo Kit with Female Connector and Stainless Steel Inlet - 30 Amp, Gray
Dobbs is offline   Reply With Quote
Old 02-11-2020, 02:31 PM   #15
Retired Member
RMWSierra's Avatar
Suggestions?
Check out smart plug at TechnoRV.com. Comes in 30 or 50 amp options.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
RMWSierra is offline   Reply With Quote
Old 02-11-2020, 10:45 PM   #16
SailorSam20500's Avatar
X3. They put that locking ring on for a reason.
I'm considering replacing my connection. If I do, it WILL be a smart plug.
Al
Save the Earth. Its the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 02-11-2020, 11:03 PM   #17
bob213's Avatar
Here...it's really not that hard to create a link....
https://www.technorv.com/smartplug-30-amp-kit/
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is online now   Reply With Quote
Old 02-12-2020, 01:16 AM   #18
https://www.westmarine.com/buy/smart...E&gclsrc=aw.ds
Old 02-12-2020, 01:32 AM   #19
"There are none so blind as those who will not see."
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
Oafdawg is offline   Reply With Quote
Old 02-12-2020, 05:56 AM   #20
DouglasReid's Avatar
It sounds to me like this is what you are looking for.
https://www.ebay.com/itm/SmartPlug-3...8AAOSwAMVeQezI
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
power, replacement
