370BL Factory Solar question
Hello all,
New to the forum as we just upgraded from TT to 5th Heritage Glenn 370BL!
It came with with the factory 100W solar panel and 30W Charge controller.
Question, the solar controller seems to only be connected to 1 of the 2 included batteries. The batteries are on separate sides in the front compartment but it appears nothing connecting the 2 for charging purposes. For testing I disconnected the furthest battery and no numbers changed nor the display inside the unit. That leads me to believe they aren't wired together. I talked to Forest River and the dealer and NEITHER were any help, frustrating! Can I just run wires between them to connect in Parallel so they both charge off the solar. Also, can anyone tell me what the 2nd battery even does?
Thanks in advance!!
