Originally Posted by harrydodge
Iam thinking about panels on my Columbus 320rs. Are you just putting screws in the roof , If not how are you finding the truss's. Palamino will not give you any info besides there are few truss's and lauon plywood over Styrofoam insulation for the roof construction? Your solar looks great ,as soon as I feel comfortable with securing them to the roof? I will be doing the same.Thank you Harrydodge
I felt the same way as you with the same questions. I had the panels assembled and ready for install for several weeks. I was not sure enough where the studs were or if the underlayment itself would hold up. I couldn't find the crossmembers with a stud finder, either.
Then I posted a pic of my roof on here and a nice poster pointed out you could see my crossmembers in the pic. They looked like seams but weren't. So I hoisted the panel assembly up on the roof and got brave enough to start screwing lag bolts into the "seams". Sure enough, there were studs underneath. I did miss one crossmember with a lag bolt and it just kept spinning, so whatever the underlayment is, it is not strong enough to hold the panels.
I will say using strut channel is a great method. Very secure and allows me some flexibility on how I mount the panels to the strut panel.
Next set is assembled and ready to go up on the roof. I'll be up there as soon as it stops raining.
