Old 07-06-2014, 08:25 PM   #1
Taranwanderer's Avatar
5 watt solar panel question
So I just purchased a Sunforce 5 watt "12 volt" battery trickle charger for my home generator--this is my first foray into the solar panel era. The Generac has a 12V tractor-type battery to start it up, and I want to keep that battery full so it's ready for use when the power goes out (I know, this isn't a camping/RV specific question, but there's so much pooled knowledge on these forums, I knew this was the place to ask.) So I'm reading the directions, and it says you can measure the output of the panel with a voltmeter (which I was going to do even before I read it,) and it says that the voltage "should be between 16 and 25 volts in full sun." 16-25 volts?!?! What happend to it being a 12 volt charger? Now I know it's only a 5W panel, which should come out to about 350mA of current, and while it does have a blocking diode to prevent battery discharge at night, it doesn't have a built-in charge controller. So is that much voltage going to hurt the battery? And do I need a charge controller for a 5W panel? I'm a little concerned...
Thanks in advance.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (18)21 (19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-06-2014, 08:47 PM   #2
You need a charge controller.
Kuba is offline   Reply With Quote
Old 07-06-2014, 09:02 PM   #3
Sunforce's website states that the product has "built in overcharge/discharge protection," but states it doesn't have a charge controller, just a blocking diode. Their site also states that any panel under 10W shouldn't be able to overcharge a 12V car battery.
I'm not opposed to buying and installing a charge controller, I'm just wondering if I need it if the manufacturer is saying I don't. I'd think they'd be saying I do need it so I'd buy more of their products...
Old 07-08-2014, 04:31 PM   #4
I have had a 5 watt panel charging a 4 amp hr battery for 2 years.
cadman99 is offline   Reply With Quote
Old 07-08-2014, 04:39 PM   #5
RPAspey's Avatar
Those voltages are normal. You're measuring open voltage. Thats just one spec of a solar panel. I doubt you'd ever over charge your starting battery.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-08-2014, 04:49 PM   #6
Is this with or without a charge controller? And has it ever overcharged your battery?
See, that's what I'm thinking too--at 5W, its not producing enough amps to cook my battery--is it? It probably getting 350mA (at best) for 3 or 4 hours a day.
Old 07-08-2014, 06:46 PM   #7
No charge controller - a waste of money on a 5 watt panel.
Old 07-08-2014, 08:27 PM   #8
RPAspey's Avatar
The only time that panel will charge is when its voltage is higher than the battery's. So once the panel starts charging, say 12 v for the discussion, your panel could theoretical make .41 amps. Watts/volts=amps. 5watts/12volts=.41amps. Thats on a perfectly clear day and at 90 degrees to the sun. Check the specs on your battery, I'd guess you are losing that much due internally. Again I doubt you will over charge the battery. A charge controller is a waste at that wattage.
solar
