09-14-2020, 10:29 AM
50 amp extension cords
looks like i will be 4 feet from my electrical socket in my new lot..
walmart has a 35 amp extension cored but not a 50..
can i use a 35 amp cord to connect to a 50 amp with my adapted and not have issues with my unit.
the lot socket has both ..
cheers
this would be for a destination cottage / park home
new to all of this
09-14-2020, 10:42 AM
I'm assuming you are permanently parked if you are a in a destination trailer?
The 30 amp with adapter will work for now but I would suggest finding a longer extension so you are on 50 amp. Even if you have to order one online. You'll be better off in the long run IMO.
09-14-2020, 10:45 AM
Location: Alberta - East of the Rockies, West of the Rest
Get a cord that is rated for 50 Amp when connecting your 50 Amp trailer to 50 Amp service! Try RV dealerships, online or have one custom made - no shortcuts.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-14-2020, 11:30 AM
Sounds like you're not wanting an extension cord, but a short power cord with the twistlock connector to connect to the RV? If that's the case, you're probably better off buying the parts and making your own. Looks like it'll cost you a little less than $100 for the parts to make one.
Gotta go campin!
09-14-2020, 11:33 AM
The 30 amp cord would be ok.
I assume you understand that a 30 amp cord only carries 30 amps!
A 50 amp cord is actually two fifty amp circuits. Thus a total of 100 amps of service.
With only 30 amps you would have to be very careful what is running. Might not be able to run both ac units etc!
09-14-2020, 01:33 PM
I would make one up to your needs. Not too difficult
09-14-2020, 01:41 PM
Unless you are experienced with electrical issues, I would suggest you purchase a ready made cord. A 30A RV requires a 2 conductor and gnd in the wire. A 50A RV requires a 3 conductor and gnd extension wired properly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-14-2020, 01:44 PM
Just make sure...
Just make sure to get the connections REALLY tight. The worst mistake amateurs make is to only snug-down the connections.
And you must observe the color code for 50-amp connections.
At both ends: - The green wire must go to the green-painted terminal
- The white wire must go to the silver-colored terminal
- The other two wires (could both be black or could be black and another color) go to the two brass (gold-colored) terminals. It doesn't matter which goes to which.
There is one thing I don't understand. The Original Poster says he is four feet from an outlet. The power cord that comes with his trailer should be much longer than that. Why is he looking for another cord?
Larry
09-14-2020, 01:46 PM
I interpreted it to mean he's going to be 4' feet short given his current cord and needs an extension. But, I could be wrong...
09-14-2020, 01:54 PM
Sounded like that you will be at a stationary spot. If you have 2 a/c then you need the heaver cord to hook up to the 50 amp. Even if you have 1 a/c I would stay with the 50 amp. to be safe what ever you are running on electric. If you are staying put and you may be adding more electric gadget down the road.
09-14-2020, 02:23 PM
Here's a 15 footer for $55 on Amazon. 4.8 stars too...
https://www.amazon.com/GoWISE-Power-...111276&sr=8-13
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
09-14-2020, 05:07 PM
Does anyone think adding an extension cord to a permanent site is a good idea? I would not want a 50 amp plug laying on the ground at my site. Once again just my 2 cents.
2017 Crusader Lite 29RS 5er 2018 Silverado 1500 5.3
09-14-2020, 05:24 PM
I elevate mine (the connection) with a sawed off 1 foot section of a 2"x4" and covered. No worries.
09-14-2020, 06:14 PM
8 years
I've had a 30 amp extension and plug lying on the ground, powered, for six years without issue. It's under the trailer, though.
Larry
09-14-2020, 06:29 PM
Originally Posted by bubbles
That 10 foot cord for $34.81 is 30 amp.
They have a 15 foot, 50 amp for $80.09
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
09-14-2020, 06:36 PM
You're right. I didn't select a length just read the info and saw the picture shown.
"Valterra A10-5010EH Mighty Cord 50 Amp Extension Cord w/Handle - 10', Red"
09-14-2020, 06:48 PM
Try this
https://www.amazon.com/dp/B00BHGXRCO/ref=cm_sw_r_cp_apa_i_teayFbBMT6NDD
09-14-2020, 07:20 PM
Kinda feel like the walleywizard.
Whether I was 4’ or 35’. I think I would prefer not to have a lot of extra cord there on the ground nor a male female connection laying in the rain! I would make one. Or have it made.
On my fifth wheel my shore power cord trailer end Plug is not the same as an extension cord. Be careful.
