Originally Posted by Bhrava
Generator cords, such as you find in box stores to power a house during a storm are rated 30 amps. No, they won't work for a 50 amp RV. A 30 amp RV can be powered with one, provided the proper ends are used.
There are 30A and 50A generator cords. All the 50A generator cords I've looked at have the typical 4 prong "RV" like plug (NEMA 14-50P) on the generator end. Some have the RV type twist lock (NEMA SS2-50R) on the building side, some have a similar looking (CS6364) connection but with a meatal point sticking out the middle.
Basically a generator plug is going to cost the same as a RV plug because the same #6 wire and the same ends are used. Other than a possible mark up for calling it "RV".
Now I'll blow everyone's mind. This year I was at a site and my 50A cord just reached. I think it was only touching the ground for about 3 feet. I decide to get an extension cord "just in case" for the future. 50A extension cords are crazy expensive. So I found this one on Ebay:
https://www.ebay.com/itm/224195109228
Sharp eyes will notice that is only #10 wire, therefore only good for 30ish amps. But it was $70 vs $200. And in three years of camping I've never needed one. And I know with my trailer with only 1 AC unit I can easily keep to less than 30A per leg. If fact I would have to "try" to exceed 30 on 1 leg. So now it sits unused in my front bin. Well Actually I used it the first trip I got it as a test. It was only a 30A site so no overload possible.
Enjoy.
Jim M.
